This one might be converted to residential.
A tour of the tower by Realty Check two years ago revealed column-free floors and stupendous views that were previously known only to employees of Deutsche Bank and the towerâs original owner, JPMorgan Chase.
It wasnât known how many units can be created at 60 Wall St. The job will be challenging in any case, due to the structureâs large floor plates. âBushburg faces a lot of planning,â a conversion expert said. He speculated, âThey might need to carve a notch into it the way SL Green is doing at 750 Third Ave. uptown in order to create apartment windows.â
Not necessarily thrilled it might go residential, but if it does I hope we see a radical reclad.
In the hypothetical situation that it does become resi, I wonder what would happen to the recent updates/reconstruction to the podium levels and interior, Iâd hope theyâd keep everything, itâs insanely nice.
Almost two thousand units can be squeezed into this edifice.
Using as metrics the average size of a Manhattan apartment (approximately 750 square feet) and the architectural guideline that about 85 percent of an apartment buildingâs interior can be used as residential space (with the rest going to common areas like hallways, elevator shafts, stairwells, and utility cores, as well as laundry and trash rooms), 60 Wall Street could yield approximately 1,920 new dwellings. That would make the project the largest-ever conversion of an office building to residential use in New York, and in the nation as a whole. It would surpass the current record holder â the nearby, recently converted office building at 25 Water â by 600 units, or roughly 45 percent. For context, this one tower may contain more homes than several multi-building residential complexes in Lower Manhattan, including Gateway Plaza (Battery Park City), Independence Plaza (Tribeca), and Southbridge Towers (the Seaport District). Based on 2020 census data, which indicate that the typical size of a Lower Manhattan household is now 2.02 persons, 60 Wall Street may bring approximately 3,878 new residents to the community.
