NEW YORK | 1740 Broadway + 870 7th Ave. | FT | FLOORS
Since I can not read the articles, and it contain older information I create this topic again on reservation. If the articles do not contain correct information I can delete this topic again.
´ˋ
I found this article via Google search "870 7th Ave“.
The two buildings combined would yield over 1.6 million square feet.
Is this the site?
I had thought there was a thread for the Park Central Hotel site, unless it came up in conversation in a previous unrelated thread months ago.
@lowkeylion there’s only <1 million zoning sf of potential space between the 2 properties, gross sf would only total around 1.2 million. Might I ask where you got >1.6 from?
@007 yes, but that was a hypothetical concept, not a real proposal.
Agreed. Although both buildings on this block should be torn down, they probably won’t be because they both exceed what is currently zoned for this block.
nothing new being built here?
Redevelopment on this site?
@SideStreet I’m still questioned by the accuracy of the MAS map, it say the Park Central site has a current FAR of 25.52, which is absolutely not the case. It’s zoned for 15, and has 665K “gross” (not zoned) sqft which would put it at around 19 Builtup FAR, but FAR does not calculate gross sqft, only zoned, so it would be closer to 15, (its designated FAR). I believe 1740 Broadway is also not over its FAR (the MAS map says its 17.61) as that is still including its gross sqft. Buildings “can” end up much larger than their established FAR and there are numerous examples throughout the city of that, but FAR itself is only including zoned floor area not gross (which include core areas, mechanical, etc) and then gross sqft is added to the max FAR, so it skews the data.
@007 I wouldn’t say so, theres no currently planned redevelopments.
Very conveniently located.
Yellowstone Plans 422-Unit Conversion in Midtown West
Yellowstone Real Estate Investments filed plans for a 422-unit residential conversion of the building at 1730 Broadway, the Commercial Observer reported. BKSK Architects was listed as the project architect on the plans filed with the Department of Buildings.
Yellowstone purchased the 520,000-square-foot site — alternatively addressed at 1740 Broadway — from Blackstone in April for $185.9 million.
Are skyscraper fans upset that this building will not be torn down to make room for a hypothetical supertall?
That market is pretty saturated right now.
new render
https://www.instagram.com/reuvenirealestate
Now that is postmodernism at its best. Honoring, and utilizing the key elements of, a beloved architectural style without being a slavish replica. I hope it turns out half as good as this rendering — choice of materials will go a long way.
Really loving this one too, would be right at home next to Radio City.
