Unfortunately both of these options would face fierce resistance from the residents in that area. They were already complaining about the noise from the airport expansion. In the long run I think a tunnel would be best however a lot more expensive.
The PA should at least leave a provision for a station in between the airport and the existing trackage. They also should not be taking full control of subway planning since that’s not their jurisdiction and I agree that the MTA should be consulted with and fully involved with the project.
Proposal 2 is stupid since it’d require long walkways to the airport and it’d likely be as inconvenient as possible (look at EWR with their station that is super far away). The Port Authority I’m sure would favour that option since it means they can still build their air train and charge you 9 dollars to get to the airport which is legitimately stupid.
I also noticed both options do not start at Ditmars Blvd which would permit both the N and W to go to LaGuardia airport although I understand why they chose what they did so they can just build over the highway to stop NIMBYs or whatever from crying about train noise. Ultimately, building a station where they planned to build the airtrain one at the central parking garage would be the cheapest solution since both terminals can be connected via a walkway that was mentioned in previous renderings.
I hope the anti-Airtrain folks are happy. Rail to LGA is officially dead. The wealthiest metropolitan area on earth is apparently unable to build rail to one of its primary air hubs. No rail connection to the subway or the LIRR, no rail connection between terminals, and thousands of airport passengers and airport employees will be clogging the roadways bc the Airtrain proposal wasn’t perfect. Congrats, NIMBYS!
Looking at the document, I now understand why a portion would have to be tunnelled - there’s a runway “safety area” and “object-free” area which are crucial for aircraft operations. There’s also the question of the Hell Gate Bridge and the challenges also associated with it. Let’s not forget the matter of utilities that would also have to be relocated for the project if certain options are chosen. This is a major reason that the “off-site” station was preferred because it avoids some of these problems near the airport.
Oh wow. That diagram certainly explains some of the unique challenges at that specific site. I didn’t realize that a tunnel would be so difficult there. Thanks for sharing.
I suppose this announcement also leaves the question of terminal connectivity up in the air. At first, the project was going to be a single terminal, then it was going to be two terminals connected by walkways both landside and airside–as well as an Airtrain. This connection was slowly whittled down to just the Airtrain, and now we don’t even have that. I wonder if they have any intention of addressing this with any means other than more buses.
I don’t think it’s that important. How many people are making connections to a different airline in a different alliance? It can’t be that many people. If you’re connecting, it’s usually with the same airline, or with a partner airline (which would be in the same terminal.)
Creating a unified airport was one of the promises of the redevelopment–I suppose there must be considerable demand given how it was such a focus. I know someone who has to make the change from B to C regularly and it’s apparently still a headache. I hope they build that landside-airside walkway along the intended path someday–the space it there for it after all.
Where is this, there is no reference to the specific site?
The PANYNJ document linked above the post that my post is referenced from seems to have been deleted or made inaccessible.
Waymond, this has some elements of an opportunity I spied, that should satisfy the NIMBY issue and some of the points made in responses here. The MTA and NYNJPA are not exactly open to outsiders (and politicans are useless), so am hoping some group participation in this forum will give some ownership and thus impetus to getting it exposed.
It is quite extensive, but highly cost effective, as you will come to see. Let’s start with the airport end of the option in the first photo, then work backwards.
I endeavoured to locate the document you linked, but could not find it anywhere in their archives. Thus, I have limited knowledge of exact placements in their design. It appears to use the center of the GCP, mostly elevated then descending below grade, rising again, with a Terminal B station over the GCP and then the final station between the GCP and Terminal C.
There the below grade portion appears to run parallel with the GCP, which is why the cross section, given in a response, makes the case of the obstacles.
The center of the GCP did not seem like the most suitable option, in my opinion, and thus I started by running it along the northern border, which seems to make the most sense, as LGA is on that side. However, for several reasons, I never was satisfied with the design options. I then noticed that a southern (Astoria Blvd South) routing was possible. First off, it was less encumbered by residential development. Then, making things better, I spied a great find, that a long stretch of that roadway had a lane which was extraneous. Other benefits soon followed.
There is a below grade section, though mostly trenched, with a short tunnel running beneath GCP, but more perpendicular to it than parallel, thus hopefully avoiding any significant obstacles.
If not clearly evident in photo, the portion running past St. Michaels would be elevated, but then begin descending to run below Astoria Blvd North (as it crosses the GCP) and 82nd St. with a trenched station just beyond 82nd.
Not apparent in the graphic, is a KEY feature of this proposed design, which makes it unique. This system will use single tracking between stations, train movements are all coordinated, making it less costly to build, more adaptive for desnely developed areas, and yet just as functional as a more costly and intrusive two track system. The benefits of this are seen in this stretch of the system, but will become even more apparent in other parts. A 20’ wide guide way has been allocated between stations in this system.
There is some practicality in what you say; give it some more thought, look at available resources.
How did you conclude that one of the traffic lanes on the eastbound stretch of Astoria Boulevard is “unnecessary”?
But highly inefficent.
Building an inefficent (what I assume to be) subway extension to save a few pennies is worse than building something properly that will be able to handle expected demand instead of fixing the already bad design later on which will end up costing more than doing it right from the start (double track). There are too many issues with single tracking and a a big one is the extreme lack of redundancy if issues are to arise or routine track work needs to take place. Any repairs or maintinenance would wipe out the entire line for the duration of the work instead of having a normal double tracked line where service can be moved to the other track. I doubt this proposal took that into account because that is one of the first things that came to mind.
This wasn’t promoted as a subway extension but as a standalone shuttle, similar to the Franklin Park Shuttle which the MTA handles fine even with permanent single-tracking. I agree that the MTA does not have the scheduling, dispatching, signaling or maintenance discipline to handle a single-track bottleneck on a full subway line.
That said, the big issue would be the need for a transfer facility at Ditmars Boulevard. Would they need to condemn and tear down a chunk of Astoria?
There is NO REDUNDANCY in short haul metro two track systems. They are configured to operate with two tracks. Anything larger than a stalled train that can be quickly ported to either a siding or the maintenance yard, is GOING TO incapicatate the entire system, no matter one or two tracks.
I wish you had paused a bit longer, given some thought, before jumping to your keyboard. This is the problem with trying to accomplish anything in public forums. Have some patience, consideration. Spend a little time looking at ALL the angles. Ask questions if you have doubts, we are trying to accomplish an end goal, not one up each other.
And no, this is not going to run off of an existing subway (2-track) line . . . thank you for kinda asking.
No Waymond not at all. The concept which came about when I saw the available (we hope) track bed on the Amtrak viaduct. The Penn Station access project might try to screw this up, but it should not, doesn’t have to.
I noticed the available track when I scanned back to look at all resources. Then what really seemed COOL, that I’d not thought of before, was that an airport line, could run ‘more or less’ east west, going from the Metro North station on 125th, to the Woodside LIRR station. By this way you are connecting with many lines.
This is jumping ahead of where I wanted to be, but, . . .
There are several more graphics to come, getting down to the guideway and property details.
Waymond, unfortunately the site made an arbitrary decision to limit new members. Stupid, I know. I roughed up a reply in a graphic, I should think after some rational thought, you’d have come to see what I wrote. Here is that rough up. I have many more graphics, explanations and such, but this sight is too lame.
You can find it all here (if they’ll not delete it out), but I won’t be able to answer any more questions, . . .
There is also a Reddit on it, NewYorkTransitLGA.
Have you given thought to a longer tunnel between East Harlem and Lawrence Point, then a surface shoreline alignment to the airport?
