NEW YORK | 8 Carlisle St (111 Washington St) | 789 FT | 64 FLOORS
You answered your own question 1 day ago, irrespective of how accurate it may be.
I know. I just gave a rough estimate of when it may top out. It might’ve topped out or it may top out in a few weeks.
Again, look at 50 West St, is it still taller than this? Yes…
From Broadway
Not a great angle, but it’s fine.
Is one of my post texts being copied or is it just me?
looks like they’re starting the crown no?
Steel for the parapet itself hasnt started, thats just the concrete bulkhead inside the crown.
:-1:t2:
I think I might’ve rushed
From the engineers
IT TOPPED OUT this building had a good run.
Unless the building got shorter, this is most likely a topping out of the superstructure (which isn’t uncommon) and not the final height.
Definitely them finishing the concrete structure itself as the last photo from @JC_Heights looks like the bulkhead is well above the scaffolding. Should expect steel soon to finish the crown
Poking out from 5th Avenue
I believe they’re two floors into the crown section:
Correct, they’re currently below
The serated slab edge should eventually come into view once the cocoon is removed more. And the rest of the crown parapet will be steel.
I think this building definitely had a good run. I don’t know how it was this fast.
A good run? You’re saying that like construction is 100% complete
