JERSEY CITY | 2966 Kennedy Blvd (Imperial Tower) | 637 FT | 56 FLOORS
looks pretty nice!
Assuming this is the final re-design, then it’s still pretty pleasant overall. The top half reminds me a little bit of 88 Regent (Liberty Harbor). I just wish they would’ve extended the “Lotus petals” detail up to the top of the structure to make the building even more striking along the JSQ skyline.
I like it. It kind of looks like a candy bar being unwrapped.
Next Planning Board meeting is tomorrow
The developer and union patched things up:
It was approved 5-2.
From the Planning Board presentation last night:
One more rendering from the Planning Board presentation:
Design could be better, but it’s not totally boring. Glad JC is getting another tall residential.
Why does it look like the PTAC units just end before the top of the tower?
It’s a lot easier to use alternative HVAC methods near the top of the building because the tubes for the coolant don’t have to travel as far to get to the mechanicals on the roof.
Higher-quality renderings (courtesy of MVMK’s instagram)
Back at work pumping concrete :building_construction:
You can see the rebar around the core that they’re using to reinforce the structure to add 20 floors.
Saw this today. Is this common? Should we be concerned?
looks like setback balconies. The rendering depicts some. Unless you mean the color of the concrete, which can vary over time.
It seems like they’re finally done retrofitting the existing structure for added weight due to the height bump, and finally pouring concrete on the top floor again. Hopefully it’s straight up from here.
Finally framing out for a new floor, for the first time in at least a year
ETA to when this will start rising? I miss seeing a tower going up when I’m on my commute to the port authority
