HOBOKEN | LOW-RISE / GENERAL Development News + Construction
A vacant former bank branch along the main drag of Hoboken will soon be meeting the wrecking ball in favor of a mixed-use complex that will add several new storefronts to the streetscape.
Designed by Nastasi Architects and modified slightly from the proposal that emerged in 2022, the fully approved plan calls for a five-story building that includes a total of 45 residences. 43 of the units will be located in the “main building” fronting Washington Street, while a pair of three-bedroom spaces will be built along Court Street over a reserved parking space below.
The residences otherwise break down as 24 one-bedroom units, four one-bedroom plus dens, 14 two-bedroom units, and one three-bedroom unit. Five of the apartments will be set aside as affordable housing per Hoboken’s local ordinances.
The development will add significant retail to this lively stretch of Washington Street. A total of five storefronts spanning 9,775 square feet will be located on the ground floor and partially in the cellar of the building.
Current construction progress as of 8/29
1200 Madison Street
Designed by New York-based architecture firm Skidmore, Owings & Merrill, the development would feature a tiered design while rising 21 stories and 230 feet above the Designated Flood Plain at the tallest points.
The 1,301 residential units would span from studios to three bedrooms, and 135 affordable housing units would be created under the plan. The largest phase of the project, including 535 residences, would be built first, while the second and third phases would consist of 365 units and 401 units, respectively.
wouldn’t be surprised if the part over the street gets cut
Progress on 301 Washington St as of 9/24/2025
Great updates, @Kevin_Dyer! This is going to be such an improvement for Washington Street-
Old:
New:
Why the design change❓
301 Washington St as of 10/10/2025
Progress on 301 Washington St. as of 10/21/2025
1301 Willow Avenue
Another gas station bites the dust :clap:
A gas station near the northern end of the Mile Square City could be redeveloped into a mixed-use complex with a sizable storefront as remediation work has already begun with plans in the works.
Excavation is underway at 1301 Willow Avenue in Hoboken, which has been home to a Sunoco gas station with four pumping stations, 3 shop garage stalls, and a small service office for many years.
Designed by MVMK Architecture + Design, the plan proposes demolishing the existing gas station and replacing it with a six-story mixed-use building with a modern design. The complex would include a total of nine residential units consisting of four two-bedroom and five three-bedroom spaces.
Update on 310 Washigton Street
Source
