NEW YORK | 8 Carlisle St (111 Washington St) | 789 FT | 64 FLOORS
well, that’s your opinion - I’m a creative and I have a completely different perspective
Chinese propaganda at work
Bookending Wall Street. - taken from the East River end
This building has the ability to pop from every corner
Might I assume the x’s are temporary?
These ones seem permanent, like those at 111 W 57th St. Its not unusual for tall steel crowns/parapets to have bracing.
It doesn’t match what the renders show. Possible V.E.?
V.E. or just plain old bait and switch. If the x’s are permanent the elegance of the crown design goes out the “window”.
A parapet having bracing doesn’t equate to something being VE’ed just as a render not showing said bracing doesn’t equate to that either. Renders are not gonna show everything 100% accurately, it’s no different here than at 111 W 57th St, because those renders never showed the bracing at the top either.
Though the design has very slightly changed you can see the bracing in the diagram.
Most of the crown glazing will probably be shadowboxed and opaque (as is indicated with the diagonal hatching above), though I will reserve judgement for after it’s finished, you won’t really notice the bracing after the cladding is put up. The render was deceiving anyways, it was never going to be 100% see through to the sky as if there was no bulkhead or structure or bmu/other rooftop equipment.
A closer look from today. You can see the glass railings and the stepped crown design.
Thanks TKDV, good explanation and it gives me hope it will turn out like the renderings.
Thank you for all you do @JC_Heights :grinning_face:
https://www.instagram.com/mchlanglo793/p/DfCz8-JEfT2/?img_index=12
Crane’s coming down
It’s crazy how fast this building rose.
Topped out 12 months after reaching street level.
